show only preferences from menu system
jan 10 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 10 years ago • 5
Is there a way to show only preferences (or other category of main menu) by pushing menu (or custom made) button?
Satisfaction mark by jan 10 years ago
Planned
We are planning on adding more menu button shortcuts, hopefully this can be implemented in version 4.04
So, at the moment your answer is: no. That's too bad
No tricky way to get there anyway?
I'd like to show only the preferences, especially the language, so customer can change language, and read the conditions in his own language, just before he enters system, blocked by PIN code
Ok, thanks,
I already discovered and applied that option
I will be looking forward to see version 4.04 !
You can prevent Adjust and Measure from being shown by using either the Visible property or a Security level for accessing all adjust and measure groups. You can also hide the logs in this way.
But the menu will still show the option to enter the System info and Moudles info
