Expansion Bus and J1939 on the same bus CAN
Louis DUBARLE 10 years ago in IQANdesign • updated by fdube 8 years ago • 2
It is possible to use tha same Bus Can for two different CAN systéme .
J1939 an Expansion on the BUS CAN C on the MD3
Image 423
When I look the project check, I don't have error.
Image 424
Best regards
Jean-Baptiste
RGDH
Develloper for IQan system
Answer
Answer
Hi, yes you can share J1939 and expansion Bus.
Only Generic CAN can't be mixed with the other protocols.
One thing to consider when you share a CAN-Bus line is the traffic load. You can measure it with IQAN analyze.
Answer
