Static IP and IQAN-SV not working together
We have an MD4-7 set up with a static IP to connect to over a local network. We added an IQAN-SV camera to the display (Network on C3, and camera on C4), after which we were unable to see the display over the network. I removed the camera from the code and it came back. Is there a reason why adding a camera would affect the diagnostics ethernet communications?
Hello Greg.
What IQANdesign version are you using and what is the static IP you have set for the MD4?
I tested a bit here to see if i got the same issue but for me it works.
I used IQANdesign 7.06 and IP 10.100.100.10 when i tested.
Did also test in 6.08 and it worked but sometimes i had a hard time finding the MD4 and needed to restart it.
Version 7.06
IP 172.26.7.55
C3 ethernet is connected to our craft network and C4 ethernet is connected directly to the camera.
Through the switch I was unable to see that module through IQAN. I could see other modules (separate IQAN Projects) on the network. When I removed the camera it was visible again.
