calculation order Hold Position
Jamy 3 weeks ago in IQANdesign • updated 2 weeks ago • 2
IQAN Design 7.06.22.11482 -
I recently encountered a calculation order issue during a complex calibration sequence. To resolve the problem, I manually adjusted and curated the calculation order so the calibration routine would execute correctly.
A few days later, I accidentally selected Auto Calculation Order, which immediately overwrote all of the manual changes I had made.
Is there a way to lock or protect manually curated calculation order entries from being modified when Auto Calculation Order is executed? Alternatively, is there a recommended method for preserving manual calculation order changes so they are not unintentionally lost?
No, you can not lock only parts of the channels when doing auto order.
What you could do is to have those channels in a separate function group, the auto order will only change in the group you are currently in.
Ok, thank you for the quick response. I was hoping to avoid having to pass all of that information back and forth between a new function group, but I'll give that approach a try.
Thanks again for your assistance.
