Insufficient rights to send application with IQAN RUN 7.06
The clone is getted without level security (log out) with the IQAN Run v7.02.8.7037
Send Clone with Dealer level security and IQAN RUN v7.02.8.7037 is OK
Send Clone with Dealer level security and IQAN RUN v7.06.18.7872 is KO
Could you fix this bug fastly ?
It is very critical since the software is edited with IQAN Design v7.06.22.11482 :
The IQAN RUN Tool is requested to upgrade to the last version for send the idax software file by the dealers...
And the dealers has not the IQAN DESIGN Tool.
And on the other hand, i cannot record the software into IQAN Design v7.04..
BR
Hello.
I have tried to replicate the issue you have here in the office but for me it works just as the first example.
I am using IQANrun 7.06.18.
Are you sure that the application in the modules you are trying to download to are the same?
Is this a remote connection you are using or locally?
I am thinking about if the connectivity setting in the application is different, that only affects remote connections.
Hello Thomas,
The connection on the CAN bus is made by PEAK USB or IQANGO Bluetooth module;
For sending the clone with the IQANRun 7.06.18, i must connect as "Engineer" or "Root" Login Level.
We have adjust items for "dealer", "Factory" or "Engineer", we must now connected with the higher level now ?
>> I added an empty adjust groups as "View/Adjust" only by "root" in the software;
>> And now it is not possible to send the clone with "Engineer" login level with IQAN Run 7.06.18...
