Sending project system failure
Kimmo 10 years ago in IQANdesign • updated by Gustav Widén (System support) 10 years ago • 4
Hi this is my firs time and i have problem with sending.
in order to upgrade the md4-5 to version 4.00 and later the module must first be upgraded to at least version 3.17?
How i do this
My connektion is ethernet cable
Answer
Answer
Hi Kimmo,
Regarding the dialog saying that you need 3.17 or higher, there were preparations made starting in version 3 to be able to upgrade to version 4. To upgrade a module with a 3.16 or earlier version, you need to do it as a two stage process, first sending a blank 3.17, 3.18 or 3.18 to the MD4, and then sending the actual application in 4.00. All the blank file needs is the master module.
Answer
Hi Kimmo,
Hi Kimmo,
If you don't have a 3.x version of IQANdesign, you can find these versions of IQANdesign here (follow the link in the bottom of the page for older versions and download the IQAN Creative Studio): http://divapps.parker.com/divapps/iqan/IQANstudios.html
Thanks this is ok.I send 3.18 blank and then my actual application. Now it's works. 😊
