Not a bug
function group output order
Jean-Marc Zanni 10 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 10 years ago • 1
Not sure when this started. But I thought that the function group output order on the display was predicted based upon the calculation order. It does not appear that it is the case anymore (Was it ever?). It seems that the Last appears first then the other follow the calculation order. Am I correct?
Here is an example:
Image 466
This is how the parent group appear:
Image 467
Thanks.
JMarc
Satisfaction mark by Jean-Marc Zanni 10 years ago
Not a bug
They are listed in the order you make them function group outputs. It is not connected to the calculation order.
