How to show measure trace on master module ?
Phan Hiep 10 years ago in IQANrun • updated by Ulrik Zakariasson (Software development) 10 years ago • 3
Hi every one. Anyone know how to show measure trace on the master screen. I know it can do when we run the simulator, but I need to show it on the screen.
Can you help me this one? Than you so much
If your master is an MD4 you could possibly use the line graph feature. It is described on page 310 of the IQANdesign user manual.
Thank you David H, the line graph can use for 1 channel, how can we show many channel on 1 graph like measure group in IQANDesign ?
+3
Yes, you can add multiple Line Graph controls on top of each other. Just turn off background and axis labels for all graphs except the bottom-most. You may also want to make all top-most grids transparent.
