State parameter and function parameter
Ed Schippers 10 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 2
I have a small problem with the adjust menu in the md4.
In the application there is a function parameter linkt to a state parameter.
Both are in the same adjust group.
In this situation when the state parameter is changed the function parameter should also change to the other value.
This doesn't work in the menu system, it works in the application.
When you leave the adjust group and then go back to this group the value has been changed
So it looks like that the screen doesn't update after the change of the state parameter,
leaving the old parameter value to show.
This is very confusing for the customer.
regards,
Ed
Very old post, but I saw it was never answered. The behavior is the same so I think it still has relevance.
When adjusting a parameter with modes, the mode one is adjusting is locked. This is intentional, to avoid the risk of accidentally adjusting the wrong mode.
