Software Roll Back
Nick Pridham 11 years ago in IQANrun • updated by Gustav Widén (System support) 11 years ago • 5
Hi, is it possible to roll back from 3.xx to 2.xx. I tried starting in safe mode but this did not work.
The requirement is generated due to working with different clients who are at different stages field software usage. I only have one MDL2 for testing and just wanted to be able to go back and forth with software OS's.
Thanks
Nick
Satisfaction mark by Nick Pridham 11 years ago
Sorry I should have clarified - I want to roll back MDL2 firmware.
Declined
Using IQANrun 3.x (or 4.0) you should be able to send a 2.x application (*.ida)
Hi Nick,
I see that you posted this as a helpdesk question and not as a public question. Since it is a general question, is it ok with you to move it to the public part of the forum?
