Standard sim pincode modem
Conrad Elektro 10 years ago in IQANrun • updated by Gustav Widén (System support) 10 years ago • 1
What is the standard sim pin configured in the IQAN G2/G3 modems? Knowing this we can put that code on our simcards
The IQAN-G2 modems are not delivered with any SIM card pre-installed.
The IQAN-G3 modem has a built-in SIM card. Attached is a file that can be used with the the load settings menu for modem settings in IQANrun
ProemionDefaults.ims
[ISP settings]
APN=internet.m2mportal.de
Username=m2m
Password=sim
DNS1=
DNS2=
Roaming=1
[SIM settings]
PIN=2304
SMSC=+491710760000
These settings should be pre-configured in the G3 modem when it is delivered.
An important point mentioned in the IQAN-G3 instruction book is that in order to use the built-in SIM card, this must be activated using the Proemion web portal.
