CAN network setting via adjust Functional Parameter?
Forrest 10 years ago in IQANdesign updated by Ulrik Zakariasson (Software development) 9 years ago 2
I would like to be able to adjust CAN Network parapeters with a functional parameter so I don't need countless iterations of the same program to get mixed up.
For example; I use a dedicated bus to speak to the Chassis computers. Most vehicles run at 250 kbs, but more and more are 500 kbs.
Another example; Most joysticks will be on short enough wires to stubs, but some cases I will have to do dual joysticks both quite distant (wire-wise) from each other and the MD3. To make that work I will need to make them their own backbone and turn off the terminating resistor on the MD3.
just that quickly I have 4 versions of the same program I need to keep up-to-date.
Termination can now be controlled with digital parameters by placing them in an initialization function group, new in IQANdesign 5.
