Is it possible to change an adjustable text parameter (or open the menu system) from an interactive message?
Dan Gray 10 years ago in IQANdesign • updated by Pierre Fagrell 7 years ago • 2
I have assigned the Action property of a button on an MD4 display page to a text parameter adjust item. I would like to do the exact same thing from a button on an interactive message. Is it possible to call up the menu system or an adjust item using qcode or some other way besides using buttons on a display page? Thanks, Dan
What you can do is to use the result from the IMGS channel to trigger the MD4 display page external button controls, this will let you enter the main menu in the menu system. See attached example
IMSG button to menu.ids4
But there is no shortcut to bring up individual adjust items from this part of the application, that could be a good feature addition.
It would be great if we could use the buttons in an interactive control to open DM1 or at least Modules list.
