Possibility to select controller in IQANrun System overview
Barth Hollanddrain 10 years ago in IQANrun • updated by Gustav Widén (System support) 10 years ago • 1
In our applications, we have an MC2 and an MD4 working as stand-alone controllers.
All data between these two is send via custom J1939 frames. this works very well for our application.
However when I'm in IQANrun and connect with a CAN-interface, all I can see is the MC2 in the System info.
When sending an update, I can choose between modules.
I would like the option to select the module when in IQANrun system diagnostics.
In IQANrun 2, you always got a Select module dialog when connecting to a CAN bus where there were multiple IQAN masters.
This select module dialog still exists in version 3 and 4, it will be shown when IQANrun cannot find a head-master, a module with address 0.
A suggestion for your application is to give both modules IdTags that differ from zero.
