Declined
Refresh adjust group when parameter changed
Laura 10 years ago in IQANrun • updated by Gustav Widén (System support) 1 year ago • 6
When I change a parameter in a adjust group and another parameter his visability is depending of that parameter the parameter that should become visable is nog visible yet.
Please refresh the adjus group when the first parameter is changed.
Now we have to leve the adjust group and enter it agian.
In the menu of te masters it is working perfect.
The behavior is the same in the MD4 menu system, that is the only place where I have thought of this limitation that adjsut item visibilty and the symbol for enable is updated only when entering the adjust group.
For MD4 menu system, I am guessing it might be tricky to change the behavior, but for the IQANrun behavior I agree that this looks more strange, as there is one page showing the adjust items, and another where adjustments is made.
Declined
We discussed this one some time ago, but I forgot to go back and update the post.
Refreshing the adjust group list of items continuously would make things more complex, better to focus on other features.
Did you reconsider this subject with the version 7.x ?
Maybe easier to refresh the menu with this new version ?
It's a shame to have to leave the adjust group and come back to refresh dispplayed parameters.
Declined
I'm sorry to say that revisited this and came to the same conclusion, functionality that would automatic refresh would be adding too much complexity for what it gives.
