Allow Simulation Change of Value with FGI
Joe 10 years ago in IQANsimulate • updated by Gustav Widén (System support) 10 years ago • 1
It would be really nice to be able to use the FGI channel to change the underlying value of the referenced channel when simulating. Otherwise it appears that it is required to navigate to and from different function groups in order to change the value and subsequently see the results of the change. If there is another method, please advise. Thanks
The method that I always use is to create one or a few simulation groups, and save them as a .isa4 file. That way you only have to locate the channels that control the FGI:s once.
I usually make the IQANsimulate window small enogh so that I can use it as a free floating window while inspecting the logic in IQANdesign.
When starting a simulation from within IQANdesign 4, it will automatically suggest using the last .isa4 file.
