IQAN Run Glitch?
Kevin 12 years ago
in IQANrun
updated by Ulrik Zakariasson (Software development) 12 years ago •
5
When we use remote access to a machine with a G2 modem and adjust variables IQAN Run crashes 50% of the time. It seems to change the adjust but when clicking on adjust button on the left after setting the new parameter it crashes IQAN Run completely?
Answer
PINNED
Problem found and fixed. Will be released in 3.15 next week.
What are the symptoms of the IQANrun crash? Do you get the popup dialog with the option to send in a crahs report to iqanbugreport?
IQAN Run simply freezes with no bug report or crash window. The page goes white and a single click in the window displays (not responding) in the top toolbar. The only way out is to control-alt-delete and close the IQAN Run process. Its only when I come out of adjust variables and click on the adjust button again.
That is strange, I have not seen this before. Is this a multi-master system? What master module(s) are you using?
We are running a multi master system, MD4 & MC3 with various expansion modules and a couple of CAN Open devices.
PINNED
