Font Selection
Metalfor 11 years ago
in IQANdesign
updated by Gustav Widén (System support) 11 years ago •
1
• 1 duplicate
Hello again. I've found that there is no way to change the font of the different variables in a display's page.
Eg: I want engine's "RPM" in Times New Roman and in the same page "ºC" of Engine Oil Temp in Arial.
Best regards. Diego.
Duplicates
1
One workaround for the example you mentioned where the unit "°C" is a static text could be to bring that in as an image instead of a value control or text control, and use the font that is set for the selected language only for the value controls on the display page.
