SV Camera into MC43 on MD4/MC43 multi-master system?
David Holcomb 9 years ago
in IQANdesign
updated by Ulrik Zakariasson (Software development) 9 years ago •
3
I am curious if SV cameras can be used on a multi-master application, where it could be wired into ethernet port on an MC43 and shown on a MD4 ?
This would be a multi master system with master and diagnostic busses between MC43 and MD4.
In IQAN Multimaster systems the masters are connected over CAN bus, (example MD4 and MC43) Connecting SV camera to MC43 ethernetport and viewing on MD4 is not possible du to limited bandwith (capacity) of CAN busses.
SV camera's should be connected direct or via router to the MD4 display modules ethernet port
thank you very much for confirming. I appreciate it.
