Adjust SPN 3350 (TSC1 control purpose)
Zach Dockter 9 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 4
Is there a way to adjust SPN 3350 of the TSC1 control in IQAN or will I need to build my CAN message manually to accomplish this?  It looks like it defaults to 31 and I need it to be 2.
Satisfaction mark by Zach Dockter 1 year ago
No, in current versions the built-in TSC1 channel has SPN 3350 fixed at 31 (original TSC1 usage / temporary powertrain control)
So to solve your application, you would need to build your own TSC1 channel using a JFOUT.
I changed category from question to idea, as this could perhaps be a good improvement to the built-in TSC1 channel?
I am currently dealing with the same issue that Zach was. Are there any updates relating to this topic?
Good timing, with IQANdesign 6.08 that was released the other month, the built-in TSC1 channel now has a property for  setting the control purpose:
https://divapps.parker.com/divapps/iqan/Downloads/IQANdesign%206/ReleaseNotes6.08.22.htm
