IQAN 5 MC43 output (HS+LS)
Frank GUO 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 1
It looks like there is no direct way to add digital out (HS+LS) on MC43. The only way I figure out was add a digital out (HS) and then change it to HS+LS. And sometimes, they are grey out.
It's available on the Add menu in the block diagram view. If you add a digital out in a function group and drag it to a module, it will be assigned to the first available digital out just like in IQANdesign 4.
