Limiting Function
Carl 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 2
Hi Guys,
In CodeySys we had a function where we could limit say the voltage input from a sensor etc.
So if we put it too 5% to 95% then no matter how higher or lower the input value was, they would stop at the limited values.
So if input was 100% the actual value out of the function was 95%, if it was 2% then the value out was 5%. is there a function in IQAN the same?
Cheers!!!
Use math channel (MAC) and there Vector, Qcode: "Result:= Vector(input,(100,95),(2,5))"
