MD4 ISO image size problem? Bug?
Ed Schippers 12 years ago in IQANdesign updated by Gustav Widén (System support) 8 years ago 4
When the same ISO image is used for a second time but with a different size, the already used image will change size.
image placed size 80x80
Image 45
same image placed but with size 40x40. it looks ok but when you look at the text you see the width and height already changed
Image 46
after closing this display page and opening is again both an the same size
Image 47
I also tried to rename one of the images, but it gives no difference
Regards,
Ed
Satisfaction mark by Ed Schippers 12 years ago
I don't know if it should be called a bug or an unwanted feature.
The problem you are showing happens if you add the image directly via the image library. Then you get only one image per ISO symbol.
The solution when you have multiple ISO symbols with different size or color is to first add them as separate images in an Image group.
This way you will have separate images.
This is solved in IQANdesign 5.04, the release notes has this text:
Images added from the image library using the drop down menus of the display page editor is now added to an image group called "Library Images". Adding the same image again will add a new instance that can have different size/color.
