I Need to lock a specific page in MD3 using PIN CODE function.
SANDEEP RAJAN 9 years ago in IQANdesign • updated by Ulrik Zakariasson (Software development) 9 years ago • 2
I need to control access to specific page using PIN CODE (PCC) function. So that only when a 4 digit PIN is entered one should get access through it.
You could add VDIN to your application, connect it to a button on a display page and also add the same VDIN as an activating object on the PCC.
Connect the PCC to the Show property on the page you want to protect.
This solution could probably be elaborated further.
