usb can interface
Richard 8 years ago in Other • updated 8 years ago • 6
National Instruments are phasing out the USB-8473 connector and  recommending the  USB-8502 unit as a replacement, has anyone verified that this unit will work with IQAN?
I have tested some basic functions with that adapter and IQAN 5 and had no problems with it.  Send Project, Get Project, Measure, etc.
Thanks Edward
Have you tried IQAN analyze? As some connectors do not seem to like this software.
Sorry, i did not.  I will check and see.
NI made their API compatible, we have the new USB-8502 here and it works with the IQAN software tools. I have updated the knowledge base article:
https://forum.iqan.se/knowledge-bases/2/articles/231-usb-to-can-interfaces
Thank you Gustav
Have you tried the Peak  unit with IQAN analyze? This may be a slightly cheaper alternative as the NI unit is quite expensive.
Just read update !! Doh
Yes it does, thanks
