LM3D conversion kit
Niklas 5 years ago in Levers • 0
Hydraulkompaniet in Sweden have put together a plug-n-play solution for replacing LM3D joysticks. No software update or wire harness modification is necessary in the machine. Just install the connectors and the LC6 with the mounting adapters.
Its possible to use the 4th axis of the two LC6 joysticks to control extra functions on the machine to even add more value to this conversion. The MC41 have 2xCOUT that will be used in this case, the externa supply needs to be connectet if COUT is used.
Link to the kit in our webshop:
https://www.hkhydraulic.com/styrsystem-elektronik/spakar-vippor-knappar/minispakar/lm3dkomverteringlc6
Installation Guide:
Youtube video
