8x 0-10V Input Module
mgarner 4 years ago in Expansion modules • updated 4 years ago • 2
I am looking for a module that can accept 8x 0-10V inputs, but all I am able to find is an XC41. Is there a better way to do this than teaming up 4x XC41's?
Why don't split the voltage using 2 resistors? i used to do so using two 4K7  resistors so 10 Vdc becomes 5 Vdc and can be used in a normal VIN
Image 3390
A voltage divider is what I am planning on using if I cant find something else, but I was hoping I could clean up the install and get rid of the resistors.
