LC5 intermittent fast blink no contact error in MC43 system
Rhys Nicholls 2 years ago in Levers / LC5 • updated by Gustav Widén (System support) 2 years ago • 4
We are experiencing faults across multiple machines with LC5 levers.
The fault presents intermittently as a no contact error, and requires a power cycle to resolve.
The LC5 status light shows a fast blink pattern of 2 yellow, 15 red, then approx 30s of high frequency red blinks. See attached videos (split into 2 parts due to size restrictions).
The MC43 in the system shows an R3:1 no contact error blink sequence. Please note that the LC5 is connected to our MC43 via an expansion bus connected with CAN-A. Our application cycle time is 20 ms.
The bus CAN-A contains 3 other devices. When the fault occurs, the other devices on CAN-A continue to transmit/receive CAN messages.
So far we have tried:
1. Checking canbus termination: 56 ohms
2. Increasing the polling cycle time from default to 80 ms.
3. Checking CAN bus utilization. Busload after the of the fault was measured at
approx 36%.
Image 4667
We have also tried to replicate the fault by manually disconnecting power/can from the LC5, with no success.
Can anyone provide more information on the causes and possible solutions for this error?
lc5-fast-blink-SN-421040085-2of2.mp4
lc5-fast-blink-SN-421040085-1of2.mp4
Thanks in advance for any assistance.
Rhys Nicholls
My recommendation is to check the CAN bus for physical problems. Looking for issues like too long drop lines, lack of termination or over-termination, or large voltage potential differences between nodes.
Running a trace with a CAN analyzer that counts error frames can indicate problems.
We have also been experiencing the same issue.
We have used the LC5 joysticks with an MC43 controller successfully on many occasions, but this is the first system we have incorporated an MD5 controller. Typically our systems have always used the MD4.
As above, we have double checked our physical CAN connections, increased the cycle time of MC43 to 60ms, and the cycle time of the MD5 to 100ms.
Bus load at fault is approx. 25%.
This fault is very intermittent, sometimes occurring after 8 hrs, sometimes as long as 60hrs.
We are currently using firmware version 7.04.8, but are thinking of downgrading to 7.02.31.
Sincerely,
Darren Robertson
Image 4740
Darren and I are still looking for a solution. We do not know what is causing the joystick stack overflow error (The LC5 status light shows a fast blink pattern of 2 yellow, 15 red, then approx 30s of high frequency red blinks). Please help.
