+3
Simulink example
Marcel 10 months ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 7 months ago 4
I would like to get familiar with the ‘Simulink model' functionality while my colleague is working on the model. Unfortunately, there is no example in iQan Design which I can try. Is it possible to get a (simple) example of a Simulink model? Just to get familiar with it?
Thanks!
Simulink Test Point Channel
Marcel 3 months ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 4 weeks ago 5
is it possible to use the value of the Simulink Test Point Channels in iQan? Or is it nessecary to create an Output port to use the value? Or a workaround maybe without changing the Simulink Function Group?
Best regards,
Marcel
Image 4125
multiple simulink top models
hongxiang yu 3 months ago in IQAN toolbox for Simulink updated 3 months ago 6
Does the IQANdesign only allow to add one simulink model in application ? I got an error "multiple simulink top models" when two simulimk modes were added in application.
Have any limitation aboout generated .ism file size or how many inside function block levels in IQANdesign ?
I was successful add a simulink model into IQAN but IQAndesign is always crashed when I try to make one more function in the model. No special error during converting to ism file. (I am using IQANdesign 6.08 version)
Simulink models possible in MC43FS/42 FS ?
hongxiang yu 6 months ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 6 months ago 1
Is that possible deploy simulink models for MC43 FS/ MC42 FS in IQANdesign 6.08 ?
IQAN toolbox for Simulink verstion 1.0
IQAN toolbox for Simulink verstion 1.0.3 is now released.
IQANdesign version 7 requires updating to this version, see:
IQAN toolbox for Simulink -supported versions / Knowledge base / IQAN
Information about the toolbox and download link here: IQAN Toolbox for Simulink
For details on the update, see release notes
Simulink with lots of inputs and outputs
Marcel 9 months ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 8 months ago 1
We are working with a Simulink model with a lot of in and outputs (20+ at the moment). Every time I get a new model (we are testing the machine) I need to relink al the in- and outputs by hand. I foresee I have to do this a lot in the near future. Is there an easy way so I don't have to relink al the in- and outputs by hand every time the simulink model is updated? Or combine all or some of the inputs to one for example. Now we use digitals, integers and reals.
Thank you!
Error while converting Simulink model into IQAN file
Friso Meeusen 2 years ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 2 years ago 14
For a project I am trying to convert a Simulink model, DOF3_RRR, which consits out of DOF3_Robot and DOF3_ForwardKinematics into an IQAN file. However, I keep on getting this error in the build sumarry: "Code generation file does not exist.". You can find the full output in the attachments:
commandwindow.asv
commandwindow.txt
I noticed three points in the output that could be the source:
Warning: File 'codedescriptor.dmr' not found.
Error: Simulink Coder Error: Simulink Coder Fatal: Failed to compute step size for TID=[0...1] in 'ModelReference' Block: '<Root>/Robot'
Model Action Rebuild Reason
DOF3_RRR_IQAN2 Failed Code generation information file does not exist.
Please let me know if you have an idea to fix this.
Thank you in advance!
IQAN toolbox for Simulink .mltbx file?
gyawali 2 years ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 2 years ago 1
I am trying to implement control logic for my application in Simulink for MC-43 Parker module. However, I cannot find the installation file for the toolbox anywhere. Could you please help in this regard. Thank you!
Matlab -Simulink for MC41
GRANJOT 3 years ago in IQAN toolbox for Simulink updated by Edward Polzin 3 years ago 2
Summary of the application: The controller receives, with a certain frequency, CAN messages containing data from 5 or 6 sensors in the system. We are going to program Lookup tables in the controller using Simulink. Lookup tables will be used for processing input data. This processing generates informations to be sent to the central controller. When we say Lookup tables, we are talking about several tables of size which may be important. The size of these tables can reach hundreds of MB.
Questions :
In the case of simulation, we will not have memory problems because these tables will be in the Matlab workspace. However, in the real application:
  • Will these tables be saved in the controller?
  • Does the internal memory of an MC41 allow it?
  • Does this not affect the computational time performance of the controller?
  • Could you confirm the possibility of using an MC41 for this application?
  • Could you confirm the possibility of using the Simulink lookup tables in an IQANdesign application?
In the training given to us by RGDH, we did not talk about the use of Matlab-Simulink in IQANdesign, and there are very few tutorials on the subject, Could you please provide us with documents or tutorial videos on the Matlab-Simulink-IQANdesign coupling?
Exporting issue
Abhijit Das 3 years ago in IQAN toolbox for Simulink updated by Gustav Widén (System support) 3 years ago 8
I am seeing the following error with Simulink export (the config file is attached). Can you please tell me how I can direct my config to generate code specifically for MC43? I am connected to MC43 through a Kvaser Leaf 2.
 Shared config
Shared config
Image 2327
Image 2330
Image 2331
Answer
The IQAN preferences menu should normally be set to build both target and simulator code.
If it is set to only build simulator code the code will run in IQANsimulate on the PC, but cannot run on a physical IQAN-MC4x hardware (the target)
