+26
IQANrun - Bluetooth connectivity
Raimund Pelz 8 years ago in IQANrun updated by Gustav Widén (System support) 2 years ago 6 1 duplicate
Please add the possibility of Bluetooth connectivtiy to IQAN Run for maintance purpose between Laptop and IQAN controller via G11 Bluetooth adapter.
+11
Mobile Phone app
Carl 5 years ago in IQANrun updated by Gustav Widén (System support) 4 years ago 3
Hi All,
Our customer base is getting larger and larger where we offer machines with a G11. The main issue always arises that most customers have mobile phones, few have tablets. IQANRun is only tablet / PC based and our customers keep asking for it on mobiles. This would be a big benefit to a lot of people.
+6
Iqan RUN adjust items must be organised in the adjust groups
Sven Bertilsson 7 years ago in IQANrun updated by Ulrik Zakariasson (Software development) 7 years ago 0
For consistency reasons and short labels, you may have adjust items ( parameters ) with the same name in different adjust groups.
When in Iqan run reviewing actual settings it becomes impossible to know which one you are looking for,
My proposal is to have a possibility to organise the adjust items in the same way as in IQAN design adjust groups.
+5
IQANrun 7 released
Gustav Widén (System support) 8 months ago in IQANrun updated 3 months ago 4
New GUI
IQANrun 7 has an updated user interface, more similar to IQANgo.
Online operations System, Logs, Measure and Adjust are on tabs at the top of the window.
Send operations such as send to machine and get clone are available with one click on the main menu.
Image 3853
When clicking connect or selecting an operation that requires connection, a connect dialog is shown. The tab for last used interface is selected as default.
Image 3856
Single adjust such as function parameters can be adjusted directly when entering the adjust group, giving better overview when adjusting. Click on value to type in or use +- buttons.
Image 3857
Adjust items with multiple values E.g. COUT is presented in a more compact form.
Image 3852
New and improved adjust view
Image 3854
Application viewer in a separate Window
Other features
IQANconnect free
Remote connections no longer require a separate IQANconnect license.
Inform of firmware update
IQANrun now shows confirmation dialog informing of firmware update.
Image 3855
In a multi-master system, the version info shown is for the address 0 headmaster.
See also Release notes - IQANrun 7
Compatibility
IQANrun 6 compatibility
  • IQANrun 6 can be used with version 7 systems; online operations as well as send application and get clone. IQANrun 7 is necessary for view project.
IQANrun 7 compatibility
  • Support file operations down to version 3.
  • CAN adapters need 64-bit support
  • Minimum OS version Windows 10
+5
Edit Settings File (irs4)
Gary Posey 7 years ago in IQANrun updated by Richard 6 years ago 1
It would be great to have the capability to edit a settings file.
To edit the parameter's Default and Current settings, while offline and remotely from the controller.
This would permit a large number of parameters to be changed easily, as well to cross check them as all parameters are visible in your spread sheet type of format.
This would give me (the Designer) the ability to send a modified settings file to a service technician in the field to send to the controller. This simplifies the service technicians tasks and reduces entry/adjustment errors at site where he/she may have limited communications with the factory/designer.
+3
security level for "unrestricted clone"
GPARRY 7 years ago in IQANrun updated by Gustav Widén (System support) 3 years ago 9
Iqan Run clones no longer pull settings I think a clone should be exactly that an identical copy of the software your cloning.
I would like a clone to pull settings regardless of security level
we set OEM settings at the factory and our dealers have less privileges so when they clone a display and send it to a new one none of the settings go with it
we really need a clone to be exactly the same!
This may be a long shot:
Memorizing channel values timer channel values excreta pulled into the clone
+3
IQANrun feedback and missing feature from earlier versions
Fredrik Forsberg 8 years ago in IQANrun updated by Ulrik Zakariasson (Software development) 6 years ago 2
  • Measure groups has to be set in IQANdesign before measuring in IQANrun. You cannot make your own measure groups in IQANrun anymore and thats a step backwards as it was a nice feature often used when troubleshooting/analysing machines.
  • Auto scale scales all the curves in different scales. The curves does not gets the same scaling.
  • Possibility to reverse the zoom steps is missing in graph.
  • Filename not visible on saved measurement when looking at a graph.
+3
Select multiple channels in IQANrun
DavidH 9 years ago in IQANrun updated 7 years ago 10
Is there be a way to select multiple measure items while viewing measure group data in IQANrun using left mouse and shift or ctrl keys? When I want to isolate just a few items, or turn all on or off, I have to pick each one at a time.
+3
Create new Measure Group with IQANRun 3.xx
Mirre 9 years ago in IQANrun updated by Ulrik Zakariasson (Software development) 6 years ago 7
Lose ability to scale and zoom measure files when saved and opened later
705David 3 months ago in IQANrun updated by Gustav Widén (System support) 1 month ago 4
When you first take a trend using measure in IQANRun 7.01, you have access to a menu with the features:
- Show status bar
- Zoom to extend
- Auto Scale Split
- Auto Scale Join
- View Cursor Range
- Comment
This menu goes away when you open a measure file that was saved. This makes analyzing measure files later very difficult.
