Graph measure as script action
Hello
It is possible to make a courbe with a Script and print this Measure
Thank
IQANscript 7 released
Updated user interface
- Introduced Add button, same as IQANdesign
- Reorganized script action categories
- New icons for script actions
Other features
Support scripts based on IQANdesign variant
Scripts can be based on .idvx variant project files. Note that send project is not supported in this version.
Script info level
In IQANrun, a script info level can be set to show when actions are executed.
See IQANscript release notes for more.
General html links in IQANscript
Would be great to be able to include links in the script.
For example:
<a href="mailto:email@example.com">Send Email</a>
or
<a href="C:\IQAN\foldername">Open folder</a>
To help the user find clones or reports and send emails.
IQANscript Expand All Action Groups
Would be nice if there was an 'Expand All' option for Action Groups in IQANscript.
Mark text to be able to copy text
It would be great to let the user mark text in the script to be able to copy text.
Scrape All Logs From Batch of Clone Files Into Excel/txt Files
Is there a way to save all logs from a clone into an excel file for a batch of clones? I'm not familiar with IQAN Script and we don't use it at all but, Ill learn it if this is possible. Use case: we receive many clones from the field as part of our warranty process. I want to compile these clones into a folder and then scrape all the logs into text or excel files. Can be a single file or one per clone. Hoping to identify which alarms we see most commonly across are machine models. The save as excel using IQAN run works it just requires saving each log group for each clone which will be very time intensive. A start would be if I could save all logs for a single clone in a single step.
I think they may have been asking for something similar here:
https://forum.iqan.se/en/communities/1/topics/1200-generic-get-all-logs-action-in-iqanscript
What are people using IQAN script for?
I am starting to play with IQAN script and trying to see what the real benefits are. Any insight as to what people are using it for, or if anyone is willing to send me some files to look through and play with (other than the example) I would be interested in dissecting it a bit.
Any insight is appreciated, thanks in advance.
iqan script 4.07 & 5.0 execute argument
I am trying to call a cmd file with a variable as an argument from IQAN Script 4.07.4.3814 and 5.04.4.4385.
Rather than the value of the variable, I get the text written in the argument i.e. %VariableName%
I am just doing a test the file is very basic.
On the script page I set the job number text field, the run command continues the script, then the variable gets set, and then process.cmd gets called.
Everything except the argument is working properly.
Is this a bug?
Generic "Get All Logs" Action in IQANScript
Is it possible when using a script to login and get logs, to just get all logs without having to pick them from the application? I'd like to make 1 generic script that logs in with the Root access and gets all logs for a long list of projects that have differently named logs and different arrangements.
thanks,
Report filename depending of the machine ID
Is it possible to program the report filename in a script report so that the machine ID is placed in the report filename with a piece of text in the windows explorer.
Now all filenames of the different machines are the same.
They are placed in several folders with the machine ID, but it is not a unique name.
Kind regards,
Laura
