USB to CAN interfaces
All IQAN masters on the IQANdesign platform supports diagnostics over CAN. To use it, a CAN adapter is needed.
The CAN adapter needs to be supported by the IQAN software, currently the following models work:
  • National Instruments NI USB-8502  (www.ni.com): Isolated. Earlier NI USB-8473 only works up to version 6 due to only having 32-bit drivers.
  • IXXAT USB-CANcompact (www.ixxat.com): Make sure to get the isolated variant.
  • Kvaser Leaf (www.kvaser.com): Several models exists, most or all isolated.
  • Parker Vansco USB-DLA (old) : Not isolated. Requires IQANdesign 2.60.34 /IQANrun 2.60.29 or later. Does not work with IQANanalyze. Only works up to version 6 (32-bit drivers).
  • CAT CA3: Requires IQANdesign 2.60.34 /IQANrun 2.60.29 or later. Does not work with IQANanalyze. Only works up to version 6 (32-bit drivers).
  • PEAK PCAN-USB (www.peak-system.com) Requires IQANdesign 4.06, IQANrun 4.06 or IQANanalyze 4.06, or later. Make sure to install both drivers and the correct API, see also Communicate with PEAK adapter / Software / IQAN.
Use diagnostic CAN bus
If possible, there should be a dedicated bus for PC-diagnostics on the machine. If this is not possible, PC-diagnostics can be mixed with expansion modules or J1939, but the amount of traffic on that bus needs to be limited.
Multiple master modules
With a multi-master system built in IQANdesign 3 or later, all masters are connected to the Diagnostics bus, this bus should be used for PC diagnostics.
If the master modules are on version 2.x, multiple master modules can also be connected to one bus for diagnostics, then each master must have a unique address, and connection can only be made to one master at a time.
Using the PC tools
Select CAN under communication options. If communication does not work, restart IQANdesign/IQANrun.
The connection to the master module is established as soon as you start an online operation, e.g. send application, adjust or view logs.
Modules with USB?
Some older modules (e.g. IQAN-MD3) was originally designed with USB in the module connector.
For the modules with a USB connection, using CAN is still the preferred diagnostic interface.
While USB is fast and available on any laptop; it has some inherent limitations. Due to its high speed and low signal amplitude, it is sensitive to disturbances. When performing run-time diagnostics such as measure on a mobile machine, this can lead to problems with constant termination of the measurement.
Another issue when connecting a PC directly to a master module is that there is a risk of damage due to voltage variations causing over current in the USB-ground. Therefore, connecting without galvanic isolation should be avoided.
USB direct connection is available up until IQANdesign 5 / IQANrun 5.
This article was helpful for 22 people. Is this article helpful for you?
