iso 7000-2596
Zach 11 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 6
Looking for the iso 7000-2596 in the library of iso images.
Is there an alternative image I can use for the malfunction/failure of emission system in the library?
Satisfaction mark by Zach 11 years ago
Good point, we missed this symbol. It will be added to the image library.
I want to mention that when I pull two of the same image with the intent of two different colored same icons, one icon becomes the color of the other.
Like if I get 7000-2423 (not sure if correct) for a engine profile with an "!" as a yellow color, and then the same as a Red, well then they both turn red.
So I worked around it with a symbol without a "!", and one with, though technically that is not right to do.
Thanks for all your help Gustav. You guys have helped me a ton!
Thanks!
Add image from library to a new group, Thanks!!!
Bug report created for not being able to add same image with different size/color.
The issue of ISO images with different size/color is now solved in 5.04
