Difference between version Github
Florent Mirieu de Labarre 9 years ago in IQANdesign • updated by Gustav Widén (System support) 8 years ago • 3
Dear
Satisfaction mark by Florent Mirieu de Labarre 8 years ago
Dear
It could be great to put the file in github, to have the history of a file.
When we save a file, it is possible to save in same time the text file (with an option) ?
Regards
I concur with this. PDM is not the place for software version control.  It appears GitHub is becoming an industry standard.
Thank you Florent for suggesting this idea!
IQANdesign 5.04 released today has two method for supporting the use of version management tools, either calling up the IQANdesign file compare with a command line argument you could launch from the tool
IQANdesign.exe ProjectFile1.idax -diff ProjectFile2.idax
or saving the project file as text with this command line
IQANdesign.exe ProjectFile.idax -saveas ProjectFile.txt
See:  https://forum.iqan.se/communities/1/topics/1498-iqandesign-504-released
