MD3 Stopped - Blue screen error
Michael Carlyle 6 years ago in IQANdesign • updated by Gustav Widén (System support) 6 years ago • 1
Image 2116
Is there a way to fix this - or replace the MD3?
It is hard to tell, it could be an unusual bug that comes with a combination of firmware and application.
If you have a 5.x version of the application it could be a good idea to start the MD3 by bypassing the application and trying if that solve the problem. (specifically thinking about one case fixed in 5.01)
It could also be related to hardware, in which case the module should be replaced. Had a similar case some years ago on MDL2:  https://forum.iqan.se/communities/1/topics/736-iqan-mdl2
