DM1/DM2 Viewer MD4 Wrap text or Select To View Full Message
Chris Litwin 6 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 2
The built in DM1/DM2 viewer is a great function, but it seems to be really limited. When using an MD4 in portrait mode there isn't enough room to display everything. It would be great if it could text wrap or if the line could be selected to read the whole text. Another option could be only displaying SPN and FM1 then select to bring up the dialog again that contains all the information.
Also, is the DM1 viewer able to show more than 1 message at a time? In simulate it does not?
I agree that the length of text to show clear text SPN name, SPN number, clear text FMI description and FMI number can be problematic, especially for portrait mode.
As an alternative to line wrap, another idea could also be to have the option to scroll left-right.
Currently the list is only scrolling up down.
(that you only see one line while simulating is a limitation in IQANsimulate only, on the real system you get a longer list)
I think the changes on the DM1 viewer in IQANdesign 6.06 solves this request.
