Customize Access to Menu System
Kerry Brock 6 years ago in IQANdesign • updated by Gustav Widén (System support) 5 years ago • 2 • 1 duplicate
In and IQANdesign project file with multiple masters, is there a way to access particular sections of the Menu system?
As an example, I would like to use a button to access the menu page for logs so the user can see logs from all masters in the system and then be able to select the logs for a particular master. It appears I can only use a button to access the log file for the master that has the display page.
I would also like to access the menu page for other items such as Adjust Groups, Measure Groups, etc.  The customer would like a custom Main Menu page that fits their branding image and then be able to access the different areas of the menu system using a custom button based on their branding requirements.  Below that level the standard IQAN look will work.
Satisfaction mark by Kerry Brock 5 years ago
Duplicates 1
There has been a few similar questions requests, for examples on direct access to a log without navigating the menu system, and direct access to DM1/DM2 list.
Not as easy as it might seem, but a good idea.
With 6.06, buttons can link directly to logs on other masters, and also to modules.
33990Add button shortcut to modules and remote logs
A module can be selected as button action to directly show the module info page.
Logs for remote modules are also available for button action.
