CANopen Communication
Vignesh Namasivayam 5 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 5
Hi all,
I am trying to find some material like videos or manuals for the CANopen protocol to guide and help me program MD4 master display controller module using IQAN design. I understand the CANopen protocol but not really sure how to set up Transmit and Receive PDO / SDO in the IQAN design since there is no option to import the .eds files directly like the .dbc files.
All I am trying to do is send some commands to my node from Master and later monitor the status of my node using TX/RX PDOs.
I really appreciate any help or guidance towards CANopen. I am not able to find any existing documentations.
Thanks
Hi Vignesh, I am having the same problem too. I know this is an older post but did you manage to find anything?
Old post, but it apparently gets some traffic..
In the IQANdesign, there is a solutions library example that is worth looking at:
Image 3568
Is there any support for implementing .eds files as discussed in the original request, or is it necessary to manual enter and en/decode all frames?
Hi River, no support for .eds. I had to manually enter the frames.
There is no support for EDS (see also feature request Any plan to support importing EDS file? / Software / IQAN)
But if you can get a DBC file for your CANopen device that has the default mapping of PDOs, you could use that.
