+3
Change sample times in measurement groups
David Dahlgren 5 years ago in IQANdesign • updated by RichG 2 months ago • 6
It would be great if I could set what sample time I desire for my measurement groups.
When I start a measurement in IQANrun and save it, I get way more data than I need. I want to look a general trend and would prefer to have one sample every 1 or 5 seconds, instead of one sample for every cycle.
Perhaps this setting would be better to set in IQANrun?
Perhaps I should add I start logging in IQANrun, and when finished I save the data, usually in an excel file.
I would also like to be able to do this. I will be data logging for several days on a Frac spread and the amount of data is just to much. 1 second sample rates are plenty as it is. Its great being able to use Iqan run but without the ability to adjust the sample it makes it only good for short captures and trouble shooting.
This would be very helpful in various situations.
In these instances when only slow logging is required I always use the log inside MD4. It can fit thousands and thousands of values.
Just send the data from your MC4x module to the MD4 and have it log whenever the value changes or at specific times.
While you can bypass this issue by having a module dedicated this slower logging, that is quite the overkill solution. I would hope that there is a way to add this option is it seems simple on the surface. With software, things never end up as simple as you'd hope though.
Came to the forum in search of a way to do this. I'm reading many Vin signals that are dynamically slow. Measurement Group updates at 1 Hz would be plenty, but I need the controller to monitor the signals and react quickly if a sensor has failed. I have the Cycle Time set at 20ms.
