Custom Measure Group Colours in Run
Dave R 4 years ago in IQANrun • updated by Gustav Widén (System support) 3 years ago • 6
I have a measure group in my program that uses custom colors for the channels. The colours are setup as System colors. When I take a measure of the group in Iqan Run the channels are all set to black for the colour.
Planned
Errors with custom colors showing as black happens when graph measuring in IQANdesign.
If measurement is made from IQANrun, the colors show up correctly.
I'm not sure if this is related - but custom gradients don't seem to show in Simulate but appear on screen.(The thin lines under the Gauges are custom gradients.
The issue with gradients in simulator is different. In IQANsimulate, the gradient stops become wrong, the result varies with the length and position of the line. The editor and the real MD4 match. That issue has been reported here before, but it has turned out to be difficult to fix. In your case, the reason it does not appear at all must be that the line gets colored completely black.
