MC43 pinout documentation
Pierre Fagrell 4 years ago in IQANdesign • updated 4 years ago • 2
On page 38 in the instruction book it lists the following outputs for pin C2:50
OUT_36a
DOUT-F (HS)
DOUT-Y, -Z, -AA, -AB (HS)*
On the next page it lists the following outputs for pin C2:70
OUT_36b
DOUT-F (HS)
DOUT-W (HS)*
DOUT-X (HS)*
Can this be correct? I thought if DOUT-Z is on OUT_36a it must also be on OUT_36b
Another question is: How can I get the printout of pin assignments from IQANdesign to use pins C2:69-72 ?
For example if I am using DOUT-Y, DOUT-Z and DOUT-AA I like to move some of them to OUT_36b instead of OUT_36a and have this reflected in the exported documentation.
You are right, in the example with output OUT_36b this is controlled with the same channel/channels as OUT_36a.
Thank you for pointing out, will be fixed.
OUT_35a OUT_36a, OUT37a and OUT38a have the correct channels listed.
For the other question, there is currently no method in IQANdesign for assigning a DOUT HS+LS pin so the highside is show on the OUT -b pins in the list view.
But there is an old feature request for this here:
Posibillity to visually occupy both OUT a and b, High … / Software / IQAN
Good, then the pins are as I assume.
Also there is missing information in the list when using multiple HS+LS.
Try for example to assign DOUT-AA, DOUT-AB and DOUT-Z
Only DOUT-AB will be mentioned on HS at pin C2:50 in the list view/print
DOUT-AA and DOUT-Z will not be mentioned at high side at all
Of course even if all the three outputs were shown in C2:50 it might be useful to move some of them to C2:70 as mentioned.
