screensaver and backlight
Ed Schippers 4 years ago in IQANdesign • updated by Gustav Widén (System support) 4 years ago • 3
It would be nice if it was possible to set the defaults for the screensaver and backlight in iqan design
You can insert a math channel with a fixed or variable value and use this to drive the backlight on the display. It overrides the value set in the menu system (effectively disabling the ability to change it on screen, therefore set by the software).
Image 3606
thanks, but i still want to be able to change it without making a separate adjust group for these parameters
