MC43FS upgrade fails with traffic on separate CAN bus
Pierre Fagrell 4 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 6
I have diagnostic bus on MC43FS CAN B connected to MD4
There are CANopen devices on MC43FS CAN C
IQANdesign is connected to MD4 via Ethernet
After upgrading of MD4 is complete it shows "Routing to MC43"
At this moment MC43 starts blinking long yellow + 2 short yellow "No application available"
Rebooting shows the same blink code and MD4 then shows application mismatch
Only way to make upgrade work is disconnecting CAN C.
I have uploaded CAN log from CAN C to filedrop.
Bus load on diagnostic/master bus 20-25%
Bus load on CAN C 30-35%
Satisfaction mark by Pierre Fagrell 3 years ago
Additional information:
It works if I send application through bluetooth with G11. It does not work through Ethernet with MD4.
G11 is connected to the same diagnostic bus as MD4.
Thank you Pierre. What software version is in the system when you try to send the update?
It seems similar to an issue that was discussed in another post, and that was solved in 6.08.22, but I think the problem you see is different.
Hi Gustav.
The symptoms are very similar, but probably a different cause. I am using version 6.08.28.8214.
The diagnostic bus is also a master bus and it has the option for J1939, but there are only IQAN devices connected to it on this machine.
The problem still exists with IQANdesign 6.08.30.8216
For information MD4 production date is 210630
ccCAN version 1.12.0.0
MC43FS production date 210729
It also has XC21 connected
Pierre,
Thank you for reporting this and the off-forum help you provided in troubleshooting.
Problem is fixed in IQANdesign 7.01, ref case
58991Software update could be interrupted by traffic on generic CAN bus
Could occur in some multi-master systems. Fixed.
