Can I influence the lamp status of DM1 Out?
Marcel 3 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 4
Can I influence the lamp status of the DM1 Out message? So the status of the four lamps. I understand that the Amber Warning Lamp is activated when there is at least 1 SPN active. But what about the other lamps?
No, the lamp status on outgoing DM1 cannot be set with application logic.
It will be amber warning when there is an active DTC.
Image 3917
Wouldn't that be a good extention of this feature? Together with occurance? It seems to me like a relative small adjustment which is a big improvement of the DM1 Out feature.
2nding request for expanded DM1 out capability. use case: our telematics system is already capable of reading engine DM1 messages. A full featured IQAN DM1 sender would save us from having to use a proprietary protocol for fault codes from IQAN. Lamp status is less useful due to the limitations with multi packet transmission but, occurrence count would be useful.
