Calculation Order (migration to V7)
Wilfred Sijtsma | Hytrans 3 years ago in IQANdesign • updated by Gustav Widén (System support) 3 years ago • 1
If I want to migrate a project from V6 to V7; and I change the order of one component in a function group, then all components "fall back" to a "standard" order (the same way the Auto order function works).
Can anyone confirm if this is a bug or normal phenomenon?
I don't recognize this symptom. Do you have an example?
Are you using 7.00 or 7.01?
The only recent case about calculation order I can think is this one about the order FGIs in externals are drawn in just after updating the external.
