UTS v2.5
Brendon 2 years ago in IQANdesign • updated 2 years ago • 3
I am having issues communicated with a UTS  V2.5 +- 90 XYZ sensor over J1939.
I've  tried the UTS version 2 app shared on this link:
https://forum.iqan.se/communities/1/topics/1057-universal-tilt-sensor-uts-programming-shortcut
Seems from that thread the app may not actually work, and documentation may not be up to date.
Anyone have any luck getting this to work?
If so, are you willing to share either a sample app or provide some insight on what needs to change in the UTS version 2 app to make it work?
Using version IQANdesign v6.08.
Hello.
I have a V2 UTS that woks.
The default source address is 226 if i am not misstaken.
You can try to import to the CAN database with this dbc file.
UTS.dbc
Thanks, will give that a try today.
It's working.  Much appreciated!
