+3
Version 7.03 released
Gustav Widén (System support) 2 years ago in IQANdesign • updated by Christopher Fridstaden 2 years ago • 4
Feature highlights
Apply login to IQANdesign
Login previously defined for IQANrun/IQANgo users is now required also for IQANdesign. This modified functionality is applicable to projects where an access level is defined on any of the properties:
  • Update project
  • Remote access
  • Send settings (IQANdesign clear settings)
IQANdesign will give a warning if an access level is not defined for Update project.
Support for MC4x/XC4x-M24
Support for new hardware versions of
  • MC4x-M24,
  • MC4xFS-M24 and
  • XC4x-M24.
Applications updated to 7.03 will run on both original and -M24 versions of MC4/MC4xFS hardware.
XC4x Firmware is updated to 2.02, this version supports both original and -M24 version of the XC4x expansions.
More updates and details, see  Release notes - IQANdesign 7
IQANrun updates
  • Improved keyboard navigation and shortcuts
  • Right click popup menu added to graph
  • New command line arguments
See Release notes - IQANrun 7
What are these "-M24" hardware versions? I have not heard of them before. Made me curious :)
The -M24 versions of MC4xFS/MC4x and XC4x are created due to a need for hardware maintenance; some of the components on the board upgraded to more modern equivalents.
The main purpose of this is to ensure longevity, while keeping technical characteristics as similar as possible to the original.
A technical advantage -M24 has over the original is better CAN transceivers.
Thank you for your answer, Gustav!
