Unable to get clone: request rejected by master module
Matt 2 years ago in IQANrun • updated by Gustav Widén (System support) 2 years ago • 1
We are having issues in the field with some of our service groups not being able to pull clones from our machines. I have attached a photo I was sent from the field. The machine in question has a MD4 [0] and two MC43s [1&2].
The program was installed using design 6.08.30. They are using Run 6.08
They have also tried using run 7 to pull the clone with the same results. Is this a bug or do we need to adjust a setting somewhere?
Image 4601
I'd say it is a bug, but I am still not sure what it is that causes it.
I believe you have been in contact with one of our Regional Application Engineers to see if it is possible to get an IQANrun log using 7.03.
There is a workaround described here: Cannot pull a clone / Software / IQAN
