CAN bus joysticks
Melker Göransson 2 years ago in IQANdesign • updated by Gustav Widén (System support) 2 years ago • 1
Is there any example or documentation to read regarding how to use joysticks with can interface? And what to think about to get it safe and smooth. Thanks.
All examples I have for safe use of joystick signals are made for analog joysticks such as LST, LSL, LC5-05 and LC6.
For example: Using dual crossed signals / Knowledge base / IQAN
For a CAN bus joystick, it should have a SIL or PL rating and come with a safety manual that describe how to use it.
Easiest way to integrate a safety rated joystick into an IQAN system is if it supports the J1939-76 protocol.
