Don't have Sufficient Rights to send Project
Michael Carlyle 1 year ago in IQANrun • updated by D CBN 4 days ago • 3
Image 4924
Has anyone come across this problem - the machine has been logged into with Service access and password and then keeps asking for the password again and always rejects when trying to update with a project file.
IqanRun 6 is being used in this case.
Not sure what the problem could be, but one thing to be aware of is that all master modules that are currently running in the system checks if the logged in user is allowed to make the update.
I have the same difficulty with IQANrun 7.06 : for send the software, i must log in with the highest access level in security parameters (as "Production & Service").
And if you change the access level used for "Change machine ID" as Allow all, then you can log in as "allow all" for send the software...
For comparaison with IQANrun 7.02: i can log in as "allow all" for send the software with "Change machine ID" as Production & Service : it works fine without insufficient access rights.
(https://forum.iqan.se/communities/1/topics/4630-insufficient-rights-to-send-application-with-iqan-run-706)
